Just wondered if anyone managed to have a look at the circuit to comment?
You posted your circuit at 17:38 GMT last night and asked at 04:51 this morning. That's overnight for those of us in the UK and Europe so a lot of people won't even have seen it until about now.
The only major error I can see in the top circuit is you have connected leg 14 "0V" to 5V / V+ rather than to 0V.
I don't know why but I feel like my circuit is too simple ... Would an analogue input spice it up a bit?? eg. using an LDR to act as a motion sensor?
There's nothing wrong with simple circuits; its what it does which matters. In fact "the simpler the better" is a good design principle to follow.
Unless adding an LDR, having motion detection - if that even works, adds any value to what you are creating I can't see the point. And how would you add that anyway ? Just to spice-up the circuit; it's not necessary, just adds unnecessary complexity.
In respect of "simplest is best", your pressure sensors with pull-down resistors to B.5, C.0 to C.3 could use internal pull-ups and pads to 0V rather than 5V. That saves 5 resistors; even simpler.
I would move the pot to B.5 and use C.0 to C.4 for your five pressure pad inputs. That will make it much easier to read all five pads in one go with a 'b0 = pinsC & %00011111".
I would also wire the pot (VR) across V+/0V and take its wiper to B.5. That saves another resistor and it will be better than trying to use a 1K pull-up with a 47K pot.
I would also move the buzzer from B.0 / Serial Out to B.4, use B.0 to B.3 for your four LED outputs. That will make it easier to program in-circuit if you decide you want to do that, which is always recommended to have.
That does beg the question though; you have 5 or 6 trigger buttons but only 4 LED outputs ?
5V --.-----------.--------------------------.--
| _ | .----------. |
| _|_|_ `-----| V+ 0V |---. |
`---o o---.---->| C.5 B.0 | | |
.---o o---|---->| C.4 B.1 | | |
}---o o---|---->| C.3 B.2 | | |
}---o o---|---->| C.2 B.3 | | .|.
}---o o---|---->| C.1 B.4 | | | |
}---o o---|---->| C.0 B.5 |<--|---|| | 47K
| .|. `----------' | |_|
| 10K |_| 14M2 | |
0V --^-----------^--------------------^-----^--
That is in fact the entire PICAXE circuit, excluding LED and buzzer control - Simplest is best.
