binary1248
Just getting back into this picaxe code and trying to modify some exsisting code.
I need to add a switch check on port D.0 (or D.7)
Why is this code snippet showing compile error ? At if pin d.0=1 then continu
This is on a 40X2 chipset
SORRY, I found it by using the new manual, I was using an old Pixaxe code reference manual.
Corrct syntax is:
stayhr:
if pinD.0 = 1 then stayhr
continu:
NOT (the space between pin & d.0 was blowing the syntax check.0
stayhr:
if pin d.0=1 then stayhr 'THIS LINE SHOWS COMPILE ERROR
continu:
