Hi All,
I want to generate a 1kHz continuous output with an 18X on pin 3. In the past when I have done this I have used the pwmout command and a poke $8f, %01000000 command to slow the clock speed so I can acheive the correct frequency.
Now I would like to add other tones which are better generated with the sound command. However I don't want these to be affected by the reduced clock speed.
Is there any complication if I change the processor speed of the PIC on the fly everytime that tone is needed and then change it back?
Or perhaps there is a better way to acheive this tone? ( I have asked that question on this forum previously and the answer was to use the above method.)
Thanks.
Thanks.
