Keith Smith
I am in the process of building a central locking controller for my ute and while the electronics and program are not a problem, I do not understand the operation of the actulator. The actulator that I am using is a very generic and readily available 5 wire "Steel Mate" brand, this one comming from Jaycar Electronics. The actulator seems to sit in a neutral position until 12 volts is applied to the motor which causes it to extend, stop and try to draw approx 3 amps. Removing the power causes the actulator to return to the neutral position. Applying 12 volts in the oppisite direction causes the actulator to retract, stop and draw approx 3 amps. once again removing the power causes the actulator to return to the neutral position. Cearly I do not understand how to drive these actulators, I was wondering if anyone else has had experience with these devices?
