puddlehaven
I've been having difficulty programming legacy devices (M, X and X2 devices) with the tool chain that I've used for years. I noticed the problem when I upgraded my Programming Editor software to the version before the current one (5.3.4, I believe) and I continue to have the problem with the current version of the software (5.4.0).
At first I thought it might be a problem with the 3-wire serial cable that I've been using. I decided that now was the time to upgrade to a USB-based programmer, so I bought one from PH Anderson. Unfortunately, it didn't fix my problems.
I am able to use the "Check firmware" button in the Programming Editor to see an 18M2, but all other devices report that there is no PICAXE present. I've tried a 20X2, two 18X chips and two 08Ms with no luck. I've tried two 18M2 chips, I can see both. One of the 18X chips and the 20X2 chip continue to run the programs in them without problems.
On one breadboard, I've got a project that includes an enhanced serial download circuit that I used to program an 18X. I can no longer see or program an 18X in that circuit; however, when I replace the 18X with an 18M2 I can see and program the 18M2 with no problems.
I've tried two different connections between the PC and the PICAXE, an Airlink 101 USB to Serial converter and a Modern Devices USB BUB II. While neither of these devices is an "official" product, I've used the Airlink 101 since 2007, and the USB BUB II is highly recommended. I can use either of these to connect to an 18M2, but neither will connect to anything else.
Here's the environment that I'm working with:
I've tried doing a complete uninstall/reinstall of the Programming Editor software , but that didn't have any effect. I'm at a loss right now, and couldn't find anything that helped on the forum -- though if you know of anything out there that addresses this I would sure like a pointer to the post.
If nothing else I'd like to try an earlier version of the Programming Editor software to see if that's really the problem, but I didn't keep the installer for the old version and there aren't any links to earlier versions on the Rev Ed Web site.
Any suggestions on what might be wrong?
- Toshiba laptop running Windows 7
- The Prolific driver from the Rev Ed Web site
- Airlink 101 USB to Serial Adapter -or-
- PH Anderson's USB BUB II - based set up, with Tx and Rx reversed.
- Enhanced serial download circuit on a breadboard -or-
- Standard serial download circuit on a breadboard -or-
- Enhanced serial download circuit on a project board that previously worked fine
- Regulated 5-volts from a wall wart -or-
- 5-volt regulated power from the BUB II
- Programming Editor 5.4.0
