Hi All
I just can get the command let outpinsB = %00000000 to work.
There seams to be no syntax error, but when I run the program, it will not make the pins output as per the %00000000 . ie%10010010
Im using a 18M2. Reading the manual, this command should work, so not sure what Im doing wrong.
So any suggestion are greatly appreciated.
Thank you
Thank you
