I am trying to install the latest Programming Editor. During the install it is trying to remove old versions of programming editor.
First I get a message saying: "The feature you are trying to use is on a network resource that is unavailable. Click OK to try again, or enter an alternative path to a folder containing the installation package 'Programming Editor.msi' in the box velow. Use source: C:\DOCUME~1\Adrian\LOCALS~1\Temp\_isD\".
Pressing OK does not do anything.
Pressing Cancel causes another message to popup: "Error 1714. The older version of Programming Editor cannot be removed. Contact your technical support group."
Trying to remove the two old version (5.1.7 and 5.2.0) using windows add/remove programs causes the same pop-up message.
How do I remove the old PE so that I can install the latest?
