CAN question
BCJKiwi
There are OBDII interfaces with serial I/O. The serial can be interfaced to the PICAXE of course - you just need to fork out $$ for the interface.
This was the best I could find when looking a while back. Baud rate adjustable on this one to 128000 (unlike most which are fixed at relatively low rates);
http://tunertools.com/proddetail.asp?prod=OBDpro_serial
There is also a reasonable amount of free "dashboard display" PC software around - some supplied with this unit.
kam
No.
But that's too short to be accepted as a post so you get this as well.
OK post too short, Got It.
The Serial to CAN makes sense. but wouldnt it affect the Performance and cost as well?
I think i read somewhere that the CAN protocol can be achieved with some coding in C... oh i think it was an ATMEL AVR. but not too sure.
Hippy, would you consider this to be a statement long enough to be considered a POST??:D;):rolleyes:
look i even added some smilies:p
BCJKiwi
The OBDPro in the reference above is a self contained and fully tested unit. It runs on a PIC inside and as indicated can run VFast serial (or USB if you get that model).
I presume by 'performance' you mean the PICAXE program performance.
Sure it will cost and it will be slow to the extent that;
1. the car will respond to the request on the CAN bus which depends on what the car is doing - tasks are prioritised depending on what is going on - you don't really want the traction control and/or ABS braking waiting around for the hung session on your homebrew PIC code do you?!!?
2. the serial comms speed.
I don't know what your application is but I for one certainly would not mess with a homebrew CAN interface unless on a completely non critical system (which I could not conceive of having a CAN in the first place).
Depending on what you want to read (or heaven forbid - control) you could obtain the information by other means.
e.g if it is engine speed or road speed, you could try ignition pickups or hall effect sensors on rotating parts - these are also available with ratiometric outputs so they can be read directly by READADC.
But it's your application so its OTY!
Some micros have CAN Bus interfaces on-chip, others can handle one by bit-banging. Otherwise an external ( eg, CAN to serial, CAN to I2C ) interface will be required. That will likely have an effect on throughput, but then so would the speed of operation of a PICAXE.
Whether performance is affected depends on what is being sent, received or monitored; as long as the PC/processor can handle the dtaa before the next must be there may be some latency issues but no overall loss of performance.
kam
I agree, its a good idea to stay away from things like these till one has complete control over it. I came up with this question just randomly. I saw a few micros that had this feature and the PICAXE has a few tricks of its own, just curious if it had this one as well.
Thanx
If Microchip ever produce a PICmicro with CAN interface which gets used as a PICAXE we might see some means to use it, although it's a bit specialised for the main PICAXE target market.
We'll just have to have a pro-forma template made up for responding to, "3l33t h4xor wants BOOST Firebird-T to 480bhp hlp dad sez ok pls will pay $$$".
