hSerial is extremely flexible, since the divider for the baud-rate generator is actually specified in the hSerSetup command (B19200_16 has a numeric value of 207 for the 20x2). So, if you find the standard divider results in synching at more than a few percent off your target frequency, you can specify a slightly different divider to correct it.Working fine, thanks. I asked because I thought I had read somewhere that the 20X2 couldn't handle > 9600 but I must have been mistaken.
