Calculated pauses don't work?
ocwo92
I'm somewhat stumped with the following piece of code. I want to fire a series of flashes with a predetermined delay inbetween. But somehow I can't get the delay code to work. Here's what I really wanted to code:
[1]		pause_length = flash_delay * 100
[2]		for j = 1 to number_of_flashes
[3]			pulsout 1, 100 ' 1 ms pulse
[4]			pause pause_length
[5]		next j
where flash_delay is guaranteed to always be a number between 1 and 99, thus making the pause well below the maximum of 65535. For example, with a value of flash_delay = 40, the delay should be four seconds.
However, the pause doesn't appear to be executed, or maybe flash_delay isn't being multiplied with 100, or whatever happens.
The following code works, however, where instead of using the calculated pause_length in line 4 above, I loop a number of 100 ms pauses in lines 3 through 5:
[1]		for j = 1 to number_of_flashes
[2]			pulsout 1, 100 ' 1 ms pulse
[3]			for k = 1 to flash_delay
[4]				pause 100
[5]			next k
[6]		next j
I suspect that pause may require an immediate operand and doesn't support register-direct addressing, but I can't gather this information from the manual.
Can anyone explain to me what I'm doing wrong in the first version?
You have not included your definitions for the variables. Perhaps you have used a byte variable for pause_length (maximum value = 255)
ocwo92
You're right. I'm still new to the 08M and didn't realize that b0, b1, etc. referred to byte variables. I simply assumed this was what the registers were called. Using a word register instead solved the problem. Thanks!
John West
Without the rest of your code I find it hard to follow.
EDIT: Good going, Pete. That was what I was thinking as well.
For example, with a value of pause_length = 40, the delay should be four seconds.
That confused me at first as pause_length = 40 would be a 40ms delay. You obviously meant flash_delay=40, giving pause_length = 4000, four seconds.
