StigOfTheDump
Hi there
I bought a couple of these serial LED modules to try on my 18M2.
http://www.byvac.com/bv3/index.php?route=product/product&path=35_53&product_id=53
I connected it up pin 5 to ground, pin 3 to +5v, pin 1 to C.2 but cannot get it to display numbers. I tried with and without inverse, with pin 1 and with pin 4 and with lots of different serout strings. I also tried hserout on B.5.
The display shows ASI in the first 3 digits and the fourth is blank. If I put my last statement in a loop the letters A,S and I flicker brightly but not in any particular order. After the loop is finished it goes Back to "ASI ".
I found a thread on this module showthread.php?t=14381 where matherp was successful with I2C but can't find anything on serial mode.
I thought it would be as simple as using the AXE033. What am I doing wrong?
BV4513 DataSheet.pdf
;18M2
setfreq m8 'Min BAUD for display is 9600
pause 500
serout C.2,T9600_8,("cr"):pause 100 'Establish connection & set BAUD
serout C.2,T9600_8,("bn3 7") 'Write number 7 on 4th digit
