Ah ok - if in doubt don't use it... but if you do make sure you re-enable as soon as possible.
However the power saving I see from 5mA (sleep with BOD on) and 5uA (sleep with BOD off) is well worth it for battery life in non critical applications
... so I'll risk it and see what happens...
PS - found this in an (ahem) Atemel spec... shorter to read
but I'm sure the principle is the same...
The single-most important analog module in terms of power consumption during a sleep
mode is the brown-out detector (BOD). A BOD protects the microcontroller when the
supply voltage falls below its operating threshold by resetting the device. This keeps the
microcontroller in a defined state when the Vcc is below its operating threshold. The BOD
is not important to the microcontroller while it’s in sleep mode but it is extremely important
when it wakes up. Therefore, as a rule, most microcontrollers keep the BOD active during
sleep mode and it contributes substantially to sleep mode power consumption.
There are two ways of getting around BOD power consumption in sleep: making a “zeropower”
BOD or turning the BOD off altogether.
Since the BOD must be functional when the controller wakes up, making a zero-power
BOD may seem like the most attractive option. However, lowering the power to the analog
module can make it very slow and make it respond too slowly to an out-of-range voltage
supply. Since the microcontroller is not running any code or writing or erasing the Flash or
EEPROM in sleep mode, the BOD is not really necessary. However, it does need to be
operational the moment the controller wakes up. The solution to this problem is to have the
microcontroller shut down the BOD when it enters sleep mode and start it again just
before leaving sleep mode. This approach ensures the BOD is functioning when it is
needed without any current penalty while in sleep mode.
