Hi All,
This is what I have come up with as a first pass for the intruder alarm. I am sure there are plenty of ways to skin this cat, and I welcome alternative suggestions.
Regards
paulr
Regards
paulr
'Burglar alarm v0.4
'Mooloolaba 2nd April '09
'Using Jaycar PIR/Microwave detector
'Sensor NC connection on pin4 (08M) or pin7 (20M) pulling input LOW.
'v0.3 added exit delay
'v0.4 took out 7seg display, added pins for siren and strobe outputs
symbol buzzer = 1 'pin1 leg6 for 08M, pin0 leg 18 for 20M
symbol strobe = 2 'pin2 leg5 for 08M, pin1 leg 17 for 20M
symbol loopcounter = b3
symbol sensorsw = pin4 'pin4 leg3 for 08M, pin7 leg 3 for 20M,
loopcounter = 36 'testing for continuous sensor detect in test2
start:
high 1 'chirp to alert that alarm is starting
pause 100
low 1
for b1 = 1 to 5
pause 60000 'exit time 5 minutes
next b1
test1:
low buzzer
low strobe
if sensorsw = 1 then
goto arming
wait 2
goto test1
arming:
high buzzer 'chirp to alert that alarm is starting - time to switch off when returning
pause 100
low buzzer
pause 500
test2:
b2=0 'counter of sensor tests
for b1= 1 to loopcounter 'try x times in loopcounter, approx 10 sec
if sensorsw = 1 then 'to see if it is real
pause 200
inc b2
next b1
alarm_on:
if b2=b3 then
high buzzer 'turn on pins for alarm
high strobe
wait 10
if sensorsw = 1 then 'if still on, keep alarm on
goto alarm_on
goto test1
end
