slimplynth
I searched the forum but didn't find the info needed to get the HC-05 paired/connected to the HC-06 slave on the raspberry pi..
Below 08M2 code for the HC-05 connected to the picaxe, based on this helpful tutorial - thankfully the bt link seems to be persistent, have cycled power on both picaxe an pi several times and it's fine..
setfreq M32
symbol Rx = C.2
symbol Tx = C.1
symbol BAUD = T38400_32
symbol LED = C.4
high LED
pause 250
low LED
'debug b0
serout Tx, BAUD, ("AT+RMAAD",13,10)
pause 2000
high LED
serout Tx, BAUD, ("AT+ROLE=1",13,10)
pause 2000
low LED
serout Tx, BAUD, ("AT+RESET",13,10)
pause 2000
high LED
serout Tx, BAUD, ("AT+CMODE=0",13,10)
pause 2000
low LED
'The tutorial linked above states the pin must be the same on both the HC-05 and HC-06.
serout Tx, BAUD, ("AT+PSWD=1234",13,10)
pause 2000
high LED
'you'll want to use your mobile phone or other device to replace the zeros below with the MAC address for the HC-06 slave connected to the rpi3 - keep the commas, no colons required...
serout Tx, BAUD, ("AT+PAIR=00,00,00,00,00,00",13,10)
pause 2000
low LED 'don't be sad - it ends on an high...
serout Tx, BAUD, ("AT+BIND=00,00,00,00,00,00",13,10)
pause 2000
high LED
serout Tx, BAUD, ("AT+LINK=00,00,00,00,00,00",13,10)
End
