Hiya:
I'm starting out on a new project where I need to control 56 LEDs -- multicolors, just on and off (no fading).
I'd read about Charlieplexing (http://en.wikipedia.org/wiki/Charlieplexing) and was able to implement it on a 14M, using the LET DIRESC command, but I wanted to confirm that only physical pins 5-10 can be set up as bi-directional. Physical pins 3-4 are hard-wired input-only and physical pins 11-12 are hardwired output only, right?
To get to my 56 LEDs, I am assuming I will need an 18X, where I can use Hippy's poke methodology to turn physical pins 6-13 into either input or output as necessary, correct?
Thanks for your insights.
\dmc
\dmc
