Hello friends! Finally got new PICAXE chips in yesterday and I wanted to get a confirmation on a couple questions I had before I supply some voltage and get the magic blue smoke. So, with that being said...
1.) Can a 9V battery be used with a 5V Regulator (LM7805) to be a power source for the PICAXE?
I recalled something in the PICAXE-Manual about 9V batteries and not using them. Not just because of the obviously higher voltage but something to do with current capabilities & mA/hour. Further explanation of this would be most appreciated!
2.) Would it be more effective to use instead two 6V Lantern batteries in series for 12V, to then be fed to the 5V regulator?
My chief complaint with this path is using a total of 12V being reduced to 5V, means a lot more heat being generated. I already have a heatsink on one but I'd prefer to not have to change it out for a bigger heatsink, adding more weight to the project box and more ambient heat around my desk.
It goes without saying that there is more than one way to program/run a PICAXE, much akin to there being 1,000 ways to skin a cat. In any case, this is the route I would like to go with (using the LM7805) as I plan on taking the concept and making a breakout board or implementing into other projects so the design and capabilities of my projects are enhanced. Thanks again friends, it's muh appreciated.
The chips I have are 08M2+ and 18M2+.
