I have absolutely NO IDEA what circuitry is included with THOSE batteries.
However, when Li Ion are sold as PACKS, the circuitry is NORMALLY designed to prevent excessive discharge and a to a limited extent, excessive over-charge. In some cases (particularly laptop packs) the circuitry is designed to work SPECIFICALLY with the circuitry on the laptop charger.
If you don't KNOW what is included with a pack DON'T USE IT!
If you over discharge the pack, the circuitry is likely to switch off the output. SOMETIMES, this switch off can only be turned back on by by sending the correct I2C commands to the on-board CPU. Without the required data, that would render the pack useless.
When charging, the circuit MIGHT tell the charger what to do. Then again, it MIGHT NOT. If it does, will YOUR charger understand what it says? If it does not, will YOUR charger know when to stop?
Unlike NiCd, NiMh and Pb technologies, Li Ion cannot absorb excess charge.
Excess charge breaks down the internal chemicals into hydrogen and lithium. The hydrogen will make the pack expand until something breaks or splits. Then hydrogen and lithium leak out. The hydrogen, although an explosive gass, is not too dangerous. Pb batteries give off hydrogen & oxygen. A spark is required to ignite it. Unfortunately, lithium ignites on contact with air and/or WATER. NEVER TRY TO PUT OUT A LITHIUM FIRE WITH WATER.
Li Ion is NOT THE SAME as Li Poly.
Li Poly has a maximum terminal voltage of 4.3v
Li Ion has a maximum terminal voltage of 4.1v
Exceeding this by as little as 0.05v can cause an fiery EXPLOSION.
Most charges described as Lithium are for Poly NOT for Ion.
Use of a Poly charger WILL cause a fiery EXPLOSION.
UNLESS YOU KNOW WAHT YOU ARE DOING AVOID Li Ion technology.
Only use Li Poly with a PROPER (balancing) Li Poly charger.
STRONGLY advise all hobbiests to stick with NiCd or NiMh.
NEVER, NEVER, NEVER, leave a lithium battery charging unattended.
