Hi All
I have come to the decision that I will always be a picaxe basic command user and most of the time I will struggle with basic commands
I have copied the following from the basic command manual and still I struggle
I have copied this code from the clipboard app in PE6
What I am trying to achieve for no reason other than learning and understanding code is this
If after the gosub routine is started no matter what part of the gosub routine I am in and pin C.0 =0 instead of 1 then I wanted pinC.0 go to 0 ,stop the routine and wait on the pinC.1 to go high again
Is this possible with my coding skills or should I go back to watching paint dry
thanks oldvolt
thanks oldvolt
[color=Black]main:[/color]
[color=Blue]if [/color][color=Purple]pinC.0 [/color][color=DarkCyan]= [/color][color=Navy]1 [/color][color=Blue]then gosub [/color][color=Black]flsh [/color][color=Green]; sub to flsh if pin0 is high[/color]
[color=Blue]goto [/color][color=Black]main [/color][color=Green]; else loop back to start[/color]
[color=Black]flsh: [/color][color=Blue]high B.1 [/color][color=Green]; switch on output B.1[/color]
[color=Blue]pause [/color][color=Navy]5000 [/color][color=Green]; wait 5 seconds[/color]
[color=Blue]low B.1 [/color][color=Green]; switch off output B.1[/color]
[color=Blue]return[/color]
