I've been playing around with background serial receive and while trying to sort a few things out I tried the demo code below, all works well until the scratchpad overflows then a problem appears, some of the serial data is lost when the pointer goes to zero, the problem appears to be in the FOR/NEXT loop when the end value (last_byte_received) becomes less than the start value (next_byte_to_echo) and a dozen or so bytes disappear.
I've made some changes which seems to have fixed the problem, data can be sent and no data will be lost on the buffer overflow.
Also what would be the best way to clear the buffer so all data in it is erased and the ptr and hserptr are set to zero.
Thanks
; This example program shows how to use the serial hardware
; with automatic background serial receives.
; Serial hardware pins (C6 and C7) connected via MAX232 to
; computers serial port. Output 1 connected to an LED.
; In normal use the LED just flashes. When a background serial receive
; occurs the bytes are echoed back out for testing purposes.
symbol last_byte_received = b1
symbol next_byte_to_echo = b2
symbol counter = b3
; set picaxe type
#picaxe 28x1
; open terminal after download
#terminal 2400
; Don't forget to move serial cable to the hardware pins!
; setup serial hardware
; at 9600 with background receive
hsersetup b2400_4,%01
'loop waiting for a byte
' do something - e.g. flash LED
toggle 1
pause 500
' test hserinflag which is set when a
' background receive occurs
if hserinflag = 1 then byte_echo
' echo back out the received bytes
byte_echo:
hserinflag = 0 'reset the flag
' the last scratchpad address written to
' will be the serialpointer - 1
last_byte_received = hserptr - 1
' echo out any bytes we have not yet used
for counter = next_byte_to_echo to last_byte_received
ptr = counter ' set scatchpad pointer to the relevant address
' and then output the data @ that address
hserout 0,(#ptr,"=",@ptr,cr,lf)
next counter
' set the last byte echoed as the current serial pointer value
next_byte_to_echo = last_byte_received + 1
'loop
symbol lastbyte = b0
; set picaxe type
#picaxe 28x1
#terminal 2400
hsersetup b2400_4,%01 'Setup for background receive at 2400
Main:
toggle 1
pause 500
if hserinflag = 1 then Byte_Echo
Byte_Echo:
hserinflag = 0 'Reset receive flag
lastbyte = hserptr
hserout 0,(#ptr,"=",@ptr,cr,lf) 'Echo byte to PC
inc ptr
if ptr > 127 then 'Check for buffer overflow
ptr = 0 'set pointer to start of buffer
end if
loop until ptr = lastbyte 'Keep sending to PC until last byte
goto main 'Go back to main loop and check if more data has arrived
Thanks
