I've made a small circuit using a 20x2 which works well enough until I switch on a couple of 240ac > 24/12vdc transformers which are close by, then circuit starts acting up.
If I disconnect all wiring into the circuit so the only connection is the 5v & 0v the circuit stops playing up, but as soon as I touch the circuit it acts up again.
If I turn off the transformers then the circuit is as good as gold regardless of whether anything is connected up to it.
So it's obviously stray emf from the transformers and the close proximity of my picaxe that's causing the problem. Unfortunately because the circuit is to be used close to the transformer I can't relocate the circuit any further away from the transformers than it already is, so the question is.....
Is there a way to shield the inputs on the axe from this unwanted interference?
