Axe401 Output Pins mapping
BillyGreen1973
Hi everyone,
I have read the manuals and the axe401 pdf, but can't seem to find the answer to my problem.
I am attempting to use the ArduiNIX Nixie driver shield. (http://arduinix.com/) with the Axe401 Shield Base.
The Arduinix requires the following code to drive it's 2 BCD converter chips, bit0-3 being one chip and bit4-7 being the other.
#picaxe 28x2
#sim shield
dirsb=%11111111
dirsc=%11111111
	for b1= 0 to 99
	let b0=bintobcd b1
	pinS.2=bit0
	pinS.3=bit1
	pinS.4=bit2
	pinS.5=bit3
	pinS.6=bit4
	pinS.7=bit5
	pinS.8=bit6
	pinS.9=bit7
	pause 500
	next b1
My question is this, is there an easier way of mapping 'b0' onto the pin S.2 to S.9?
Pins S.2 to Pin S.9 span port B and port C and are not in the logical order.
The code above does work but seems a bit 'brute force' and a bit wasteful.
Thanks
It's the way I'd do it. You can create a subroutine which moves the 'b0' / 'bit0-bit7' variables out to the shield pins and then just set 'b0' and call the routine to save duplicating the code throughout your program.
BillyGreen1973
Thanks Hippy.
Yeah a subroutine would be the way I would go, Just using the code above to make sure things are working as expected.
At least I'm not missing anything dead simple!
I think a 16Mhz resonator for the Axe401 may be in order now though!
