AXE210 - Zigbee Not response
Samurai
Hi all,
I have the AXE210 board and one Xbee module.
When i connect it to the pc i can have either the following results:
1. Get Version -> "No response"
2. Get Version -> results in a series of characters like "yy.."
3. Get Version -> TX:+++ RX:OK and so on...
The board is alimented trought a +9V (600mA) stabilized power supply and connect by serial cable to pc. Only the max3232 is connected when i'm doing this.
That results remain the same also changing baud rate, (i have tried all of them almost once and for days....-_-").
Someone has got a solution for this? Any kind of help would be appreciated!:)
I'm looking forward for a reply...
Fabio
That seems to be the right sort of response one would expect, so it seems the XBee is working sometimes. It could be a power supply problem. It may be worthwhile trying with a different power supply or even using a 9V/PP3 battery.
Samurai
Yes...sometimes i got the right response...
I'll try to use a battery pack insted of a stabilized power supply or i can try to use a laboratory power supply able to reach 2A...
i haven't ideas...i checked all the solderings, all ok!
fabio
