AXE210 and Xbee questions
Is it possible to use the XBEE Pro on the AXE210 board?
Using the AXE210 board will I have access to the rest of the 18X pins to connect sensors?
The AXE210 Datasheet does not show a schematic of the complete cirduit. Is it available somewhere else?
The AXE210.PDF and AXE210_XBEE.PDF files contain schematics.
I recall there's an issue as the XBee Pro can draw a lot more current than the standard and it may be necessary to change one or both reuglators to handle that.
Hippy,
Thank you for your response. If the only problem is the power supply, I can deal with it. I was concerned with other potential issues such as interface, pinout of the XBee, etc.
I looked again at the datasheets and the only schematics are those showing the interface between the Picaxe and the XBee and between the RS232 and the XBee. I am concerned about connecting to the rest of the Picaxe I/O pins and for that, I did not see any complete schematic of the AXE210 board.
