That is the Schools Experimener Board. This is a great board for learning. It has 3 LED outputs (0, 1, 2) a digital input (3) and a LDR for analogue input (4). It also has a header and switches so that you can use a breadboard or other devices to practice with.
Here is the link to the data sheet
http://www.rev-ed.co.uk/docs/axe092.pdf or use the help menu item -> select 08/m/14/20 data sheets and find the school experimenters board.
To see if it is the board you have use the simulate function in the programing environment. Click on the simulate menu item -> simulation panels -> sim products and click Axe092 - schools experimenters board. Write some code in the code window (main: goto main is enough) and press simulate.
The picture below is the axe092 hooked up to an xbee shield used by my UAV students.
thanks
tiny
