AXE091 board and DS1307
Tony P
Page 8 of the AXE091 manual reads:
"A 3V lithium backup cell may be optionally
connected to the DS1307 RTC chip. This can be
achieved in either of two ways:
- by soldering a BAT004H-SM socket to
the bottom of the board...."
How? Where?
Please help
Tony P
Ahhhh all becomes clear. I have been sold the wrong battery holder by Techsupplies even though I bought the parts as a 'kit'
Many thanks
Tony P
My next question is:
How do I use the DS1307 on the project board? There is not much info in the manual (not that I can understand anyway!!)
Tony P
Having hooked up the SDA/SCL connections that are shared between the DS1307 and the EEPROM to the i2c pins on your PICAXE, read the i2c tutorial.
I have followed all instructions to the letter but if I try to display the time on my AXE033 LCD all I get is 255:255:255 as the time
Bill.b
Hi Tony
Could you post your code for comment.
and may be a picture of you connections.
Bill
Tony P
I have the the SCL output connected to pin 7 and the SDA output connected to pin 10 of my 18M2
#PICAXE 18M2
	hi2csetup i2cmaster, %11010000, i2cslow, i2cbyte
MAIN:
	PAUSE 2000
	hi2cin 0,(B0,B1,B2)
	DEBUG
	serout B.7,N2400, (254, 1)
	pause 500
	serout B.7,N2400, (254,128)
	serout B.7,N2400, (#B0,":",#B1,":",#B2)
	GOTO MAIN
Tony P
Sorry that is the way I have it wired. Been a long night!!
I am now getting 128:0:0 as the display and I have done nothing different
Tony P
I also realised that I posted the wrong code. Here is the correct one
#PICAXE 18M2
	 i2cslave %11010000, i2cslow, i2cbyte
MAIN:
	PAUSE 2000
	hi2cin 0,(B0,B1,B2)
	DEBUG
	pause 500
	GOTO MAIN
The reason you are seeing values like 128 is that the values you read in from the DS1307 are in BCD format.
Your will need to use the BCDTOASCII command for the seconds, minutes and hours to generate separate tens and units digits and then send these to the display.
To save on having to use many variables, use the BCDTOASCII with the hours first and send that to the display, then do the minutes and finally the hours.
Try this:
#PICAXE 18M2
MAIN:
	PAUSE 2000
	hi2cin 0,(b0,b1,b2)
	DEBUG
	pause 500
	b4 = b2 : GOSUB Convert : SEROUT B.7, N2400, (":")
	b4 = b1 : GOSUB Convert : SEROUT B.7, N2400, (":")
	b4 = b0 : GOSUB Convert
		GOTO MAIN
Convert:
	BCDTOASCII b4,b5,b6
	SEROUT B.7, N2400, (b5,b6)
	RETUR
Tony P
Thankyou Thankyou Thankyou!! westaust55
Why are things like this not written in the manuals and the example codes?
nick12ab
Yes it is - from i2c tutorial: "All the time/date data is in BCD (binary-coded-decimal) format"
To be fair, the i2c tutorial does not contain a good example for displaying the time, and the example here is not very good at all.
Bill.b
This code will display in 12 hour format. This is only part of complete clock program.
symbol TempHour 		= b24		'Tempory store - Hours
symbol OLED		= b.7		'Serial output to display
symbol Baud		= N2400	'Set serial output baud rate
symbol seconds 		= b7		'DS1307 seconds
symbol mins 		= b8		'DS1307 minutes
symbol hour 		= b9		'DS1307 Hour
symbol day 		= b10		'DS1307 day
symbol date 		= b11		'DS1307 Date
symbol month 		= b12		'DS1307 Month
symbol year 		= b13		'DS1307 Year
symbol control 		= b14		'DS1307 Control
symbol AsciiData1 	= b17		'Ascii data for display on LCD
symbol AsciiData2 	= b16		'Ascii data for display on LCD
symbol AsciiData3 	= b20		'Ascii data for display on LCD
symbol AsciiData4 	= b19		'Ascii data for display on LCD
symbol AsciiData5 	= b23		'Ascii data for display on LCD
symbol AsciiData6 	= b22		'Ascii data for display on LCD
symbol AsciiData7 	= b25		'Ascii data for display on LCD
	pause 2000
	serout OLED,Baud,(254,1)			'Clear Display
	gosub TimeDate12
TimeDate12:
	gosub readtime			'get current time form DS1307
	serout OLED,Baud,(254,128)    'calculate 12 hour display from 24h data
	Temphour = hour
	if hour >9 then
		Temphour = hour - 6
	if hour >18 then
		 Temphour = hour - 18
	if hour >25 then
		 Temphour = hour - 24
	if hour =0 then
		Temphour = 12
	bintoascii Temphour,AsciiData7,AsciiData2,AsciiData1	'Convert Time  To ASCII for display
	bcdtoascii mins,AsciiData4,AsciiData3
	bcdtoascii seconds,AsciiData6,AsciiData5
	if AsciiData2 = 48 then					'remove leading 0
		serout OLED,Baud,("    ",AsciiData1,":",AsciiData4,AsciiData3,":",AsciiData6,AsciiData5)
		serout OLED,Baud,("    ",AsciiData2,AsciiData1,":",AsciiData4,AsciiData3,":",AsciiData6,AsciiData5)
				'display am or pm
	if hour > 17 then
		serout OLED,Baud,(" pm    ")
		serout OLED,Baud,(" am    ")
	serout OLED,Baud,(254,192)
readTime:
	hi2csetup i2cmaster, %11010000, i2cslow, i2cbyte    	' set DS1307 slave address
	hi2cin 0,(seconds,mins,hour,day,date,month,year)  	'Read date and Time
Bill
Hemi345
Because it seems they don't want to give all the answers, just enough information to either push you in the general direction or frustrate the hell out of you. This topic has been asked so many times, you would think they would just put a working example on the website in the Circuit Creator section or even a link to the I2C tutorial in the Commands section of the website or Manual 2. I eventually found the I2C tutorial a few months back in the datasheets section but still looking for the elusive one-wire tutorial.
Such information is also given in the DS1307 Datasheet.
It really is worth downloading (readily available - just google) the relevant Datasheet for any new IC/chip that you are going to use.
