I now have an AXE049 (http://www.picaxe.com/Hardware/Teaching-Systems/PICAXE-Tutorial-Board/) which comes with various peripherals and there is also a pdf tutorial (http://www.picaxe.com/docs/axe049.pdf) that I have been working through.
This program - to flash the decimal point on the LED display works:
However, this program, from TUTORIAL 7 - NUMBER SYSTEMS does not work. It is supposed to display the numbers from 0 to 9 on the LED. I assumed (incorrectly?) that a tutorial program would just work fine. Can anyone advise why this doesn't work? The chip is an 18M2.
Many thanks.
[INDENT]high 7
low 7
[/INDENT]
[INDENT]let pins = %00111111
pause 250
let pins = %00000110
pause 250
let pins = %01011011
pause 250
let pins = %01001111
pause 250
let pins = %01100110
pause 250
let pins = %01101101
pause 250
let pins = %01111101
pause 250
let pins = %00000111
pause 250
let pins = %01111111
pause 250
let pins = %01101111
pause 250
[/INDENT]
