I'm starting to play with an Axe033 and I believe I have successfully connected it to a 20X2 PICAXE. Following the literature that came with it, loaded the test program (Hello!123), it worked. Than successfully loaded the sample program to load predefined messages, Player 1 and 2 as per instructions, and then the following program to display them.
My troubles start with the sample program combining predefined messages and variables. I copied the program out of the book then when it starts running on the PICAXE and Axe033 it works for the beginning then the "Player 2=" part just displays "THIS IS MESSAGE6" and on the first line, "Player 1=" appears and disappears and the number that follows displays some numbers combine with symbols.
Am I doing something wrong?
James
init:
pause 500
serout 7,n2400,(1)
pause 10
serout 7,n2400,(254,137,#b1," ")
serout 7,n2400,(2)
pause 10
serout 7,n2400,(254,201,#b2," ")
let b1=b1+1
let b2=b2+2
pause 500
James
