Heyah,
Im having a slight problem, with the pulse out on the axe033 clock. I have only just realised its a 50/50 mark to space ratio, meaning a 500ms high 500ms low output, and im using an interrupt to increment a time counter up each second.
I was at first hoping that this would mean the interrupt would fire once a second, yet after breadboarding my model tends to increment the timer by 5 or so each time pulse out goes high. To avoid that I have tried putting a 500ms pause in the interrupt, and that works fine, the timer increments by 1 each second, however the rest of my code is unable to run with a pause that big in my interrupt. A solution I have come up with is to connect the pulse out to a picaxe 08M, have the interrupt run on that, with that 500ms delay, and feed a much shorter pulse out to the main picaxe (18x). I would however like to avoid that, as using another picaxe just for such a simple thing seems ridiculous.
Is there an easy way to solve this, hopefully not using any extra chips?
My current code (Well this is an older version, I have the newer one at school, but none of the changes affect anything to do with the interrupt):
Cheers in advance... x
#picaxe 18X
symbol write.debounce=1000 'Debounce when writing to EEPROM
symbol switch.debounce=100 'Debounce when accepting input from a switch
symbol display.debounce=10 'Debounce when communicating with AXE033
init.LCD: 'Save prewritten messages on AXE033 EEPROM
pause 500
serout 1,N2400,(253,3,"Enter Password: ")
pause write.debounce
serout 1,N2400,(253,1,"T C LL ")
serout 1,N2400,(253,2,"Timer= s ")
serout 1,N2400,(253,4," INCORRECT ")
serout 1,N2400,(253,5," PASSWORD ")
serout 1,N2400,(254,1)
pause display.debounce
security:
b0=0 'Initialize variables
b1=0
b2=0
b3=197
b4=0
serout 1,N2400,(253,3) 'Display "Enter Password: " on the LCD
for b2=1 to 4 'Initialize the password entry loop
security.underscore:
b3=b3+1
serout 1,N2400,(254,b3,"_") 'Display an entry prompt "_" accounting for LCD cursor position
b3=b3-1
bit5=0 'Reset bit5 (bit 5 adjusts "_" position)
security.entry: 'Entry of password
if input6=1 then 'If backspace pressed delete last character
gosub security.back
readadc 2,b1 'Check password input switches
loop while b1<20 'Loop until there is an input
security.selectcase:
select case b2 'Compares input against the correct input, bit marked if input is correct
case 1
if b1>60 AND b1<80 then 'Range provided for relability
bit0=1
case 2
if b1>80 AND b1<100 then
bit1=1
case 3
if b1>100 AND b1<120 then
bit2=1
case 4
if b1>120 AND b1<140 then
bit3=1
endselect
pause switch.debounce
b3=b3+1 'Move the cursor forward by one
serout 1,N2400,(254,b3,"X") 'Display "X" at current cursor position to mark entered character
next b2 'End password entry process
do 'Loop waiting for password confirmation using enter
if input6=1 then 'If backspace is pressed mark bit5 to adjust cursor position
bit5=1 'and go back to the password entry phase, from which the user
goto security.entry 'will go straight to the backspace function, as backspace is
endif 'still down
loop while input7=0 'Exit loop when enter is pressed, confirming the password to be checked
if b0=%00001111 then 'Check password against a constant, if all 4 bits were marked password is correct
setint %00000010,%00000010
serout 1,N2400,(254,1) 'Clear the LCD of old now irrelevant text
serout 1,N2400,(253,1) 'Display "T C LL " on line one of the LCD
serout 1,N2400,(253,2) 'Display "Timer= s " on line two of the LCD
else 'If password is incorrect
high 0 'turn on a red LED
serout 1,N2400,(253,4) 'and display " INCORRECT " on line one of the LCD
serout 1,N2400,(253,5) 'with " PASSWORD " on the second line of the LCD
wait 5 'Display this message and keep the red LED on for 5 sec
serout 1,N2400,(254,1) 'After 5 sec clear the LCD
low 0 'and turn the red LED off
goto security 'Reset the character entry process
security.back: 'The backspace password entry character deletion function
if b2>=2 then 'If we are not already at position 1 of the LCD
serout 1,N2400,(254,b3," ") 'Delete everything after the cursor
b3=b3-1 'Move cursor and password entry variables back to accustom
b2=b2-1 'for the character deletion
if bit5=1 then
goto security.underscore
b3=b3+1
b3=b3-1
goto security.entry
if pin2=1 then
w6=0
readtemp 1,b1
if b1<10 then
serout 1,N2400,(254,131,"00",#b1)
else if b1<100 then
serout 1,N2400,(254,131,"0",#b1)
serout 1,N2400,(254,131,#b1)
readadc 1,b2
b2=b2*100/255
if b2<10 then
serout 1,N2400,(254,137,"00",#b2)
else if b2<100 then
serout 1,N2400,(254,137,"0",#b2)
serout 1,N2400,(254,137,#b2)
interrupt:
inc w6
if w6<10 then
serout 1,N2400,(254,198,"00",#w6)
else if w6<100 then
serout 1,N2400,(254,198,"0",#w6)
serout 1,N2400,(254,198,#w6)
