I'm pulling my hair out here, Im not able to install the device driver, it states - "device driver installed correctly" and then immediately after "driver not installed correctly", I have the pdf file but nothing is the same as described, no wizard comes up, and manually updating does the same. I am running windows 7 by the way.
I have checked no ports available in editor and device manager reports problem with the ! in triangle.
At the finish of setup it states -
Axe027 Picaxe USB - Ready to use
USB Serial Port - Not Found
I have tried multiple times and get the same. What am I dong wrong?
Success! - Sorry finally got it, you can delete this now, cant find the option to delete it myself. I had to go to device manager to fix it. Very confusing, none of the steps for installing were the same as I got.
