RonHackett
I've been using a simple 08M2 program to measure the voltage levels produced by the daclevel command. The circuit uses a +5V regulated power supply (actual V+ = 5.08V), and the AXE027 cable for programming the 08M2. I'm not using an op amp - just a DVM to measure the voltage at the DAC pin. For example, to determine the maximum voltage output (at DAC level 31), I used the following code:
When I first ran the program, I obtained a voltage reading of 2.60V - far below the 4.8V or 4.9V output that I expected to see. I re-ran the program several times with different DAC levels - the majority of the results were way below what I thought they should be. Then I remembered the two resistors that are attached to the TXD line in the AXE027 circuitry. To determine whether they were affecting the results, I disconnected the AXE027, and again measured the DAC voltage. This time, at DAC level 31 the voltage was 4.90V. I repeated the measurements at several DAC levels, with the AXE027 in the circuit, and without it. Here are the results:
DAC| Cable | Cable
Lev| <Out> | <In>
00 | 0.02V | 0.08V
01 | 0.18V | 0.18V
02 | 0.34V | 0.25V
10 | 1.59V | 0.49V
20 | 3.17V | 0.78V
30 | 4.75V | 2.15V
31 | 4.90V | 2.60V
Just to be sure all this isn't due to the fact that I wasn't using an op amp in the circuit, I added an MCP6021 op amp, and did another set of measurements, this time on the op amp output voltage. The results were similar: At the majority of DAC levels, whenever the AXE027 cable was connected, the voltage was dramatically lower than it was with the cable disconnected. (Levels 0 and 1 were the only exceptions.)
I did a search of the Forum, and couldn't find any mention of an issue like this, so I'm hoping someone can shed some light on this situation. Is the AXE027 cable the culprit here, or am I missing something?
dacsetup %10100000
daclevel 31
stop
DAC| Cable | Cable
Lev| <Out> | <In>
00 | 0.02V | 0.08V
01 | 0.18V | 0.18V
02 | 0.34V | 0.25V
10 | 1.59V | 0.49V
20 | 3.17V | 0.78V
30 | 4.75V | 2.15V
31 | 4.90V | 2.60V
