I just want to flash an LED from the keyboard of a PC running Win7 64, an AXE027 cable and the PIC 08 proto board. I'm using the 08M2 chip.
Here's the code I'm using:
It works fine in the simulator so I'm guessing it's a hardware problem. I can download a program no problem to the 08M2 and I've tried the jumper on the proto board in both positions.
I'm presuming this can be done with the proto board or do I have to make a separate circuit?
I've looked up the manuals but am a bit confused when they talk about a serial cable. Do they mean the old serial cable or are they referring to the USB to serial converter cable (AXE027)?
I've tried using the serial terminal in the Program Editor to input the digit 1 to get the LCD to flash in a number of ways. I've used 1,"1",49 and "49" but all I get from the input buffer is strange ASCII hierogliphics like this ŒŒÌŒŒÌŒŒŒŒŒŒÎŒŒÌŒŒ.
One further thing: I've downloaded the simple LED flasher program onto the 08M2 and kept it on the proto board and it flashes away nicely but when I reload the above program, no flashing.
Any help would be appreciated. Thanks.
Regards
Dermot
serin 3,N2400,b1
if b1=1 then high 4
low 4
Regards
Dermot
