Hi there,
I went across a nice variometer project designed around Arduino Nano which, of course, has a Arduino code totally unknown by me.
Is there anyone who can offer an initial translation of that code to Pickaxe code for a 08M?
The Arduino code is attached.
Many thanks to this community.
Benjie
Benjie
// All code by Rolf R Bakke, Oct 2012
#include <Wire.h>
const byte led = 13;
unsigned int calibrationData[7];
unsigned long time = 0;
float toneFreq, toneFreqLowpass, pressure, lowpassFast, lowpassSlow ;
int ddsAcc;
void setup()
Wire.begin();
Serial.begin(115200);
setupSensor();
pressure = getPressure();
lowpassFast = lowpassSlow = pressure;
void loop()
lowpassFast = lowpassFast + (pressure - lowpassFast) * 0.1;
lowpassSlow = lowpassSlow + (pressure - lowpassSlow) * 0.05;
toneFreq = (lowpassSlow - lowpassFast) * 50;
toneFreqLowpass = toneFreqLowpass + (toneFreq - toneFreqLowpass) * 0.1;
toneFreq = constrain(toneFreqLowpass, -500, 500);
ddsAcc += toneFreq * 100 + 2000;
if (toneFreq < 0 || ddsAcc > 0)
tone(2, toneFreq + 510);
noTone(2);
ledOff();
while (millis() < time); //loop frequency timer
time += 20;
ledOn();
long getPressure()
long D1, D2, dT, P;
float TEMP;
int64_t OFF, SENS;
D1 = getData(0x48, 10);
D2 = getData(0x50, 1);
dT = D2 - ((long)calibrationData[5] << 8);
TEMP = (2000 + (((int64_t)dT * (int64_t)calibrationData[6]) >> 23)) / (float)100;
OFF = ((unsigned long)calibrationData[2] << 16) + (((int64_t)calibrationData[4] * dT) >> 7);
SENS = ((unsigned long)calibrationData[1] << 15) + (((int64_t)calibrationData[3] * dT) >> 8);
P = (((D1 * SENS) >> 21) - OFF) >> 15;
//Serial.println(TEMP);
//Serial.println(P);
return P;
long getData(byte command, byte del)
long result = 0;
twiSendCommand(0x77, command);
delay(del);
twiSendCommand(0x77, 0x00);
Wire.requestFrom(0x77, 3);
if(Wire.available()!=3) Serial.println("Error: raw data not available");
for (int i = 0; i <= 2; i++)
result = (result<<8) | Wire.read();
return result;
void setupSensor()
twiSendCommand(0x77, 0x1e);
delay(100);
for (byte i = 1; i <=6; i++)
unsigned int low, high;
twiSendCommand(0x77, 0xa0 + i * 2);
Wire.requestFrom(0x77, 2);
if(Wire.available()!=2) Serial.println("Error: calibration data not available");
high = Wire.read();
low = Wire.read();
calibrationData[i] = high<<8 | low;
Serial.print("calibration data #");
Serial.print(i);
Serial.print(" = ");
Serial.println( calibrationData[i] );
void twiSendCommand(byte address, byte command)
Wire.beginTransmission(address);
if (!Wire.write(command)) Serial.println("Error: write()");
if (Wire.endTransmission())
Serial.print("Error when sending command: ");
Serial.println(command, HEX);
void ledOn()
digitalWrite(led,1);
void ledOff()
digitalWrite(led,0);
