Appearance of text in cells
Johnmb
In commands such as ReadADC the text does not fit into the command symbol in the cell. The top and bottom of the text is clipped. Via the control panel I have set the Screen Resolution to 1780x960 and I am running XP sp2. I have tried other settings without effect on the problem.
The Logicator is Version 3 Build 4.1. Is this normal for this Version or do I have a parameter that needs adjustment?
John
We are not aware of any issues, the text size should be the same for all commands and is not user adjustable. Could you add a screenshot so we can see the issue?
