laserhawk64
This one I might actually BUILD this year...
I saw this post on HackADay, and (as is often the case with such posts) I thought, "That is waaaaaaaay overcomplicating things!"
Could I do something similar (artificial sunrise machine) with a Picaxe 08M (not M2), an RTC (maybe this one?), and a servo (like this?)?
I've got a rotary dimmer switch to spare, that isn't a problem.
Basically, the idea (in case one doesn't want to click the HaD link) is that the Picaxe, at a time set by the RTC, starts (very slowly) turning the dimmer switch, via servo, until full brightness is achieved. Should take 30-60min to get there.
I don't necessarily need a display or config buttons; I can re-config it from a laptop if it's going on too quickly or slowly. I've got a clock already (and a few to spare) so I'm not planning on replacing it -- this is strictly an automated dimmer, it does not display the current time.
A button to turn it off is easily sourced from Radio Shack. (I'm thinking the "off" button could be implemented as a one-shot sorta thing, i.e. "if on, then when button pressed, turn off; else ignore button" -- and presto! no debounce needed.)
Make sense? or am I spouting whotsit again?
