I got a Picaxe VCR controller working a while back, with help from you guys...thanks! What this does is, tell my VCR to record when I'm receiving a signal from one of my RF video cams. When I first built it, I had stereo sound channels, so I use one of them to send a tone to the receiver, which was picked up by a 567 encoder...or is it as a decoder??? Anyway, the 567 puts a pin low when it hears the correct tone. I used the low pin to trigger a Picaxe 08M to control the buttons on a universal remote...worked great!
OK, so now I'm using the controller with a radio that has only one audio channel, and I have to have sound you know Soooo...I changed the 567 circuit to listen for the video signal coming in...and it worked pretty good.
Now....someone went and built a tower nearby, and there is something coming off that thing that messes with my RF. The audio signal had no problem getting through, but the video will ....ummmm....blink a little???
To keep the recording going when MY RF is active, I need some sort of a "filter" ???
Now I have been working on this "filter" and have close to what I want, or need. As you can see I check pin3 every tenth second, and if it is high, from interference, I count how many times it happens. After 10 times, I give it just one more chance before stopping the recorder.
The problem is this....and why I can't see it is beyond me...if everything is OK after the b2 only reaches...maybe 8 times of not being OK, it needs to reset b2 to zero again. In other words, the way it is now, even a minute or two later, it still has the demerits against it from the start. Any ideas on how to do it the right way???
recording:
do while b2 < 10
pause 100
if pin3 = 1 then
b2 = b2 + 1
b2 = 0
goto make_sure
make_sure:
pause 100
if pin3 = 1 then quit
if pin3 = 0 then recording
