A couple of years ago we discussed the need for an extension of the anchor alarm on Meridian, as my wife wasn't with me and my mate who was helping, was equally hard of hearing. Part of the problem was that there was no signal wire for the anchor alarm which gets triggered by the GPS when the position is outside the circle of safety, eg .02 or .03 NM.
The solution was to fit a piezo inside the case to pick up the beep. This was fed to a VOX circuit with the 08 between the output and the relay. The relay closed the contacts on a wireless doorbell, which could be placed close by the sleeping skipper. To avoid random noise spikes setting it off, the 08 looked for a high from the amp, waited about 10 secs for another high to activate. If nothing heard after 10 secs, it slept for 30s. (I can't find the code now).
This has worked OK most of the time but it sometime goes off with random noise, or, more worryingly, doesn't go off when it should.
So I'd like to revisit the whole idea. I have attached a zipped mp3 file of the actual alarm. It is roughly 2 seconds per on/off cycle, I was hoping that someone could analyse it more accurately in terms of frequency, period on and off. I don't have a scope on the boat any more (I did have once!).
The question is:
(a) do I sample the beeps and silences to determine a true alarm condition or
(b) ditch the amp and measure the frequency directly by the 08 and then sample?
View attachment 13678View attachment 13678
I hope that the attachment works, I haven't done this before...
paulr
The question is:
paulr
