Pauldesign
Although in the picaxe commands manual and in the Quick Syntax checker, it does shows that 18M2 supports infraout command but it seems as if PICAXE18M2 (not so sure about 14M2 and 20M2, so can't query this on them since they're still in the pipeline) doesn't support infraout command when use in Prog Edit or checked in 18M2 pin-out data-sheet.
Or is there a special way of using infraout command with 18M2 which isn't mentioned in the manuals. .
Well, i'm just reporting this if it hasn't been noticed or mentioned before, so please don't tell me to use irout command as i know 18M2 supports it and it works great.
Attached is a screen short of PE infraout command simulation error using 18M2.
