Along the lines of a different thread, can you run either hard serial OR normal serial (on different pin) in the same program ?
I am thinking along the lines of a HARD serial routine and NORMAL serial routine where you switch on Serial IN/Serial OUT for a specific pin and then switch it off again. When switching it off, you restore Hsersetup to be "ON" ???
Possible ??
Possible ??
