They are the ones
They are manufactured by Hope, type RFM02 for the transmitter, I have data sheets from RF solutions from hope and from silicon labs who make the chips in the module while they are good in the detail none of them give much idea how the fetures interact or how to use them for a simple fsk link.
Also if anyone has had trouble with the quasar quasi am/fm modules I have found that anything under 50M is to close together without coiling up the antenna to reduce sensitivity.
Of interest to others, may be the way most modules dynamically set the level to differentiate a high from a low (bit slicing), and this has a short time constant so sending raw serial data results in the level moving up and down with data containing many '0's or '1's which ends up as corrupt data, so manchester encoding which contains equal numbers of 1's and 0's solves this, I am using the encoders and decoders from rev ed with good success.
