Blazemaguire
This is my most ambitious programe yet (for me at least, go easy!) - I'm trying to make a simple keypad activated lock, but also with a 'set code' mode where the 4 digit pin can be set from within the programe.
I had the structure working fine when it was just looking for a code that was set in the original programe, but now I've added functionality to allow setting of the code whilst in operation, i've exceeded my memory by 547 bytes.
As a code novice, I do not know any shortcuts for reducing the size of the programe without reducing the functionality. - Could someone have a look and give me some pointers that I could try to reduce the size? - I'm using an 18m2 chip. - I'd rather not have to use one of the bigger memory versions.
I've started to comment the front of the programme, but the rest is repetition.
init:
symbol codepos1=140 'for determining where to display the character on the LCD
symbol codepos2=141 'for determining where to display the character on the LC
symbol codepos3=142 'for determining where to display the character on the LC
symbol codepos4=143 'for determining where to display the character on the LC
symbol scancode1=b1 'reading the code part 1
symbol scancode2=b2 'reading code part 2
symbol scancode3=b3 'reading code part 3
symbol scancode4=b4 'reading code part 4
symbol setcode1=b5 'storage of programmed code part 1
symbol setcode2=b6 'storage of programmed code part 2
symbol setcode3=b7 'storage of programmed code part 3
symbol setcode4=b8 'storage of programmed code part 4
symbol delaycode=250 'how long to display a character before moving on to next
symbol programmemode=b9 'to keep track of being in setcode mode, or scancode mode.
symbol yes=1
symbol no=0
symbol timetounlock=w9
setcode1=0 'set default code to 0000
setcode2=0
setcode3=0
setcode4=0
serout b.3,N2400,(254,1) ' clear display
pause 200
if programmemode=no then
serout b.3,N2400,(254,128,"Enter Code: ") 'display enter code on LCD if in non programme mode
else if programmemode=yes then
serout b.3,N2400,(254,128,"Set Code: ") 'display set code on LCD if in setcode mode.
low b.0,b.1 'turn of both status LEDS (red and green LED for locked / unlocked status attached to these outputs)
timetounlock=0 'reset the time unlocked variable
'read button press 1 code or setting
scan1:
'scan row 1
high b.4 low b.5,b.6,b.7 'set row 1 high and the others lows
if pinc.2=1 then 'read column 1
serout b.3,N2400,(254,codepos1,"1")
if programmemode=no then: scancode1=1: pause delaycode
elseif programmemode=yes then: setcode1=1: programmemode=no else: endif
serout b.3,N2400,(254,codepos1,"*"): pause delaycode
goto scan2
elseif pinc.1=1 then 'read column 2
serout b.3,N2400,(254,codepos1,"2")
if programmemode=no then: scancode1=2: pause delaycode
elseif programmemode=yes then: setcode1=2:programmemode=no else: endif
goto scan2
elseif pinc.0=1 then 'read column 3
serout b.3,N2400,(254,codepos1,"3")
goto scan2
'scan row 2
high b.5 low b.4,b.6,b.7
if pinc.2=1 then
if programmemode=no then: scancode1=3: pause delaycode
elseif programmemode=yes then: setcode1=3: programmemode=no else: endif
goto scan2
serout b.3,N2400,(254,codepos1,"4")
if programmemode=no then: scancode1=4: pause delaycode
elseif programmemode=yes then: setcode1=4:programmemode=no else: endif
goto scan2
serout b.3,N2400,(254,codepos1,"5")
if programmemode=no then: scancode1=5: pause delaycode
elseif programmemode=yes then: setcode1=5:programmemode=no else: endif
goto scan2
'scan row 3
high b.6 low b.4,b.5,b.7
if pinc.2=1 then
serout b.3,N2400,(254,codepos1,"7")
if programmemode=no then: scancode1=7: pause delaycode
elseif programmemode=yes then: setcode1=7: programmemode=no else: endif
goto scan2
serout b.3,N2400,(254,codepos1,"8")
if programmemode=no then: scancode1=8: pause delaycode
elseif programmemode=yes then: setcode1=8:programmemode=no else: endif
goto scan2
serout b.3,N2400,(254,codepos1,"9")
if programmemode=no then: scancode1=9: pause delaycode
elseif programmemode=yes then: setcode1=9:programmemode=no else: endif
goto scan2
'scan row 4
high b.7 low b.4,b.5,b.6
if pinc.2=1 then
if programmemode=no then: scancode1=10: pause delaycode
elseif programmemode=yes then: setcode1=10: programmemode=no else: endif
goto scan2
serout b.3,N2400,(254,codepos1,"0")
if programmemode=no then: scancode1=0: pause delaycode
elseif programmemode=yes then: setcode1=0:programmemode=no else: endif
goto scan2
serout b.3,N2400,(254,codepos1,"#")
if programmemode=no then: scancode1=11: pause delaycode
elseif programmemode=yes then: setcode1=11:programmemode=no else: endif
goto scan2
goto scan1
'2nd and third code read should happen here
'read 4th button into memory
scan4:
'scan row 1
if pinc.2=1 then
if programmemode=no then: scancode4=1: pause delaycode
elseif programmemode=yes then: setcode4=1: programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=2: pause delaycode
elseif programmemode=yes then: setcode4=2:programmemode=no else: endif
goto checkcode
goto checkcode
'scan row 2
if pinc.2=1 then
if programmemode=no then: scancode4=3: pause delaycode
elseif programmemode=yes then: setcode4=3: programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=4: pause delaycode
elseif programmemode=yes then: setcode4=4:programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=5: pause delaycode
elseif programmemode=yes then: setcode4=5:programmemode=no else: endif
goto checkcode
'scan row 3
if pinc.2=1 then
if programmemode=no then: scancode4=7: pause delaycode
elseif programmemode=yes then: setcode4=7: programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=8: pause delaycode
elseif programmemode=yes then: setcode4=8:programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=9: pause delaycode
elseif programmemode=yes then: setcode4=9:programmemode=no else: endif
goto checkcode
'scan row 4
if pinc.2=1 then
if programmemode=no then: scancode4=10: pause delaycode
elseif programmemode=yes then: setcode4=10: programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=0: pause delaycode
elseif programmemode=yes then: setcode4=0:programmemode=no else: endif
goto checkcode
if programmemode=no then: scancode4=11: pause delaycode
elseif programmemode=yes then: setcode4=11:programmemode=no else: endif
goto checkcode
goto scan4
checkcode:
if scancode1=setcode1 and scancode2=setcode2 and scancode3=setcode3 and scancode4=setcode4 then
serout b.3,N2400,(254,128,"Code Correct ")
'check for enter code programming mode
high B.7
high b.1
inc w9
if pinC.0 = 1 then
programmemode=yes
loop while timetounlock < 2000
serout b.3,N2400,(254,128,"Code Incorrect ")
high b.0
pause 3000
