Pauldesign
Hi
I'm having problem establishing infrared coms between a 40x1 Tx and a 18X Rx.
I've done the following:
- Used wired link and it works just fine.
- Keep them in rectilinear sight and in close proximity and in a dark corner but not still working.
- I've checked the IR led using a digital camera and it's flickering.
- Scoped and FFT the IR Tx pin and is centered at 42 KHz instead of 38KHz.
My approach now is to:
- But first will calibrating the center frequency (with the setfreq command) close to 38KHz helps as i'm not very comfortable playing with the internal clock.
Does anyone knows of what the 38KHz Tx carrier freq bandwidth has to be, to create COMs with the 38 KHz receiver? Any previous success using this setfreq approach with IR?
- Use a 555 timer circuit and troubleshoot it with but i'm too lazy to built one :rolleyes
Thnx
Thnx
