ADC simulation
zeus1972
I have a problem with the simulation of the analogical ADC
encircled with 40x1
the doors ADCs from 1 to 3 correctly work
while from the 5 to the 7 it doesn't work me the simulation.
the program is equal, it changes only the address of the door
thanks
Works ok for us using readadc, attach your .dsn and .bas file so we can look at them for you.
The problem is with your file, you have not used the correct V+ supply (right mouse-click, place>terminal>power). See the corrected file attached.
