I am using the ADCs in a 28X1 in 10 bit mode. I am not happy with the stabiltiy of the ADC value I am seeing.
I suspect it is a hardware issue, since, when I use a voltage divider from Vss to ADC1 and from ADC1 to Vdd, I get a reading which does not vary in the last place. When I use my application, I see a range of about +/-4 in a count of 300.
The 28X1 has two ground pins. Does anyone know if these are equal, or if one is intended for the analog part of the chip, and one for the digital side? I have looked at the Microchip website, and I can not see any reference to this.
I have a DC gain and offset op-amp circuit driving the ADC. The op-amp is a Burr-Brown OPA2344.
The circuit is wired on a piece of perf board, with a voltage regulator on the board. The 28X1 has 10nF and 2.2uF across the power supply pins at the chip. The op-amp has 10nF across the chip. I have used a star ground and power supply wiring configuration, and I have made the connection between the op-amp and the 28X1 using signal and ground wires twisted together together, and connected to the grounds and the hot pins at each end. This length is about 60mm.
I am reluctant to put caps across the feedback resistors to limit the frequency response, because I want very high DC accuracy, and the leakage of the capacitors will alter the DC gain.
I thought I read somewhere that the ADC input is not a standard analog input, but draws pulses of current. Therefore, I am reluctant to put a series R/shunt C low pass network at the output of the op-amp.
Any thoughts or suggestions would be appreciated.
Thank you.
Thank you.
