kranenborg
Dear Picaxe enthousiasts,
Since I am in need of a frequency counter for an analog electronics project I googled around and quickly ran into a nice PICAXE implementation (0 - 65MHz) that seemed to satisfy my requirements very well. Its design was published in 2006 (!) by Jeremy Leach, who has been a prolific contributor to this forum (but he has not been hanging around anymore lately I think). The thread and the original program can be found in the PICAXE archives here: Link to Jeremy's implementation
Since this implementation is really old now and on deprecated PICAXE hardware (08M) I decided to modernize it (whilst keeping Jeremy's concept and most of the implementation intact as it seems to be very well designed). I have now built it, did several tests and it appears to perform wonderfully, with a frequency (relative) accuracy of close to 0.1% (but I need to test more).
The hardware setup consists of a 28X2 (with a 16MHz crystal i.s.o. the usual resonator), running at maximum frequency (64MHz), and a 74HC4040 binary ripple counter.
The key changes I made compared to Jeremy' implementation are (as copied from the code implementation):
The code is strongly documented (but also check the 2006 thread) and includes detailed information on the hardware setup needed.
I also attached a simple 08M2 frequency generator program for quick testing of the frequency counter using 4 frequencies (4KHz - 4MHz)
PS1: There is still room for significant improvement (theoretically a tenfold increase in accuracy, and the 28X2 has many more inputs to make that happen) and I am working on that right now, but for most practical applications the current program will serve very well.
In case anyone sees an issue or improvement then I am happy to be informed!
PS2: I tested using the SETXD output, as I currently do not have an AXE033/133 LCD display at hand. But I did not make any changes to Jeremy's part of the LCD code ...
BR
Jurjen
http://www.kranenborg.org/electronics
- Jeremy's concept & code largely retained (>95%)
- Adapted 08m to 28x2 with very accurate crystal (the 28X2 is the smallest PICAXE allowing the use of a crystal as its time base) -> no calibration needed anymore!
- Significantly shorter sample times (4x - 16x) without compromising accuracy (this required a change in the divisor output selection)
- Addition of SERTXD PC-output for testing or use (in parallel to LCD display like AXE133)
- Minor comments changes + clarifications
BR
Jurjen
