Hi all,
so I couldn't get MacAxe to work with my work MacBook so I tried on my iBook G4 at home. Accidentally installed the Intel USB driver and when I connected got the message about not being able to access the USB even though it shows up in network preferences and appears to be installed correctly.
Followed the instructions about preferences both through terminal and by accessing the file. No difference.
Deleted the driver file thinking I should instead install the PPC driver. Opened that file and started the installation only to be met with a stupid message telling me I cannot continue because there is nothing to install!
Downloaded the file about a million more times thinking the first version might have been corrupted but same message every time.
Downloaded it on my other G4 thinking that the issue was caused by previously installing the intel instead of PPC driver but on the othe G4 and if I didn't make the same mistake on the other machine it would go better.
However, I still get the "nothing to install message" which suggests to me that the PPC download file is not correct.
I have 3 macs of varying spec and systems and yet can't get one of them to work!
Any thoughts, help, advice would be much appreciated.
Cheers
Cheers
