Of course, it uses a PICAXE too, in this case a left-over 14M. Most of my projects are powered either from a vehicle’s 12 V or a “wall-wart” AC power supply, and therefore contain a 5V regulator. To get at least 7.5V at end of life, an 8-cell battery was chosen since a holder for 8-AAs is available. The charger will work from vehicle 12 V or a “wall-wart” AC power supply. The charge current depends only on the battery voltage, and is independent of the load current. Without charging input, the battery will run most of my projects for nearly a day. See http://www.projects.worsleyassociates.com and click on "10 Volt battery/charger"
