I had to make a replacement for the thermostat on our spa, and I used a PICAXE for it - reported on Sep 12, 2011. As a byproduct, it reports using SERTXD. Our spa does have a Radio Shack digital thermometer but it is not easy to read, and you have to be in the spa. This has a big, bright LED readout and it sits high on a swivel so it can be read from the house too. It automatically shows the ambient temperature when the spa is off.
I'm not proud of the design because it uses a lot of ICs, which was a lot of work, but, hey, I'm retired so what's my time worth?
You might be interested if you need to multiplex common-anode LEDs, or if you use SERIN, which is tricky.
Read about it in my website: http://www.projects.worsleyassociates.com
