A few of us were discussing using the PICAXE in various curricular activities. I agree that breadboards have their place and that wiring up an 08M is not the hardest thing in the world. With that said I wanted a way to give students an even easier route into controlling things with a micro. I took inspiration from the arduino - <A href='http://arduino.cc/' Target=_Blank>External Web Link</a> - which is hugely popular at the moment and in use by NYU and UCLA particularly in the arts & design departments. Within no time at all students (and n00bs alike) can have their first hello world up and running and it also works well for more advanced applications like quickly hooking a flex sensor to a servo.
At 30$ and the more complicated language I felt the arduino could be improved upon, or at least made easier and simpler with the loss of as few capabilities as possible. So Ive been working on a small board for the 08M that could be offered in kit form (or pre-made if I could find a distributor willing) that has the serial plug built in, vreg wired up with a standard power jack, and easy access to the pinouts. I was going to wait until the prototype made it back from china to show everyone but then I found Eagle3D which is super cool so here you go:
<A href='http://www.csulb.edu/~bevans2/AXEbrd3Dblack480.jpg' Target=_Blank>External Web Link</a>
Pin0/Serial jumper at the top, LDO 5v vreg, 2.1mm power plug, can take as low as ~6v DC in, female pin headers for the pinouts (may use small screw terminals instead). You can easily wire up an LED to pin0, servo to pin4, and even an analog sensor without touching a breadboard. Overall dimensions are 1.25" x 2".
Thoughts, criticisms, comments, opinions, drive by banana flinging... ?
Brian
Brian
