Not exactly a “power” comparison but some thoughts on a similar vein.
(Nostalgia time)
My first home brew computer (mid 1970’s) was based on the national Semiconductor SC/MP chip. 256 bytes of memory, no ROM, clock speed 1MHz (from memory), all programming in machine code, input via 8 toggle switches and output via 8 LED’s. No BASIC available
Next (late 1970’s) was a home brew Motorola 6800 based home brew with 1MHz clock speed, started with 512 bytes RAM built up to 8.5Kbytes of RAM, initially 1 or 2Kbytes ROM which was expanded by a few Kbytes of EPROM, initially hex keypad with some 7-seg displays for IO which I later upgraded to ASCII keyboard (built from a kit) and using a TV video board and ex TV station 8 inch (200mm) green screen monitor. Integer only BASIC (took 4K of RAM) with around 26 variables (a to z). Programs stored on cassette tapes. Added RS232 for dot matrix printer (heck I even modified the printer to have 4 times the RAM, extra characters etc)
Third machine (1980) started life as an OSI C2-4P using MOS Technology 6502 cpu, clock speed 1MHz, started with 8k RAM and built own board to have 24 kbytes RAM, started with 9kbytes Rom which I changed to 20kbytes EPROM, on board video card with 32 lines and 64 chars per line and 16 colours – I hacked and added twice the characters, flashing and inverted characters, BASIC interpreter (floating point numbers and around 260 variables from memory). BASIC interpreter was hacked for 256 x 256 “chunky” graphics, and text to speech (added SAY keyword), extra added IO for program cartridges, etc.
From this and knowing the IO I had on each , around the late 1970’s, the home brew computers had the same “capabilities” as a PICAXE chip but needed a box the size of a PC case compared to now where the capabilities being packaged in an 8 thru 40 pin chip and with a keypad and LCD display all still can fit in a box the size of a desktop PC power supply.
