smokelight101
Over the course of the summer a few close friends and I started an endeavor to launch a high altitude weather balloon load with a few cameras in hopes to acquire a picture of the edge of space. I know safety flags of the legality of this project are racing. This project is completely legal as it is being built under the specifications set out in part 101 in faa regulations. But this doesn't mean I don't wanna hear your concerns please if you have any voice them.
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&rgn=div5&view=text&node=14:2.0.1.3.15&idno=14
Anyway to the picaxe portion. I plan for a picaxe or a set of picaxes to trigger the cameras, log some sensor data, and work as a TNC for a radio. The TNC takes a string of data from the gps then places it into a standardized protocol that amateur radio hobbyists use for tracking called APRS.
The questions I have.
1. Has any one have any experience with APRS or AX.25?
2. The radio uses different tones for ones and zeros. For example 1400hz for 1 and 2200 for 0 I believe for APRS. I may have the 1's and 0's fliped. Is it possible to do this with the picaxe?
3. When connecting the picaxe to the radios mic in and speaker ports what type of circuitry do you recommend? I was just thinking a resister and capacitor on the mic and a 800 to 8 ohm signal transformer on the speaker for impedance matching but I'm rather novice.
Wow that was alot. Any comments would be appreciated!!!!
Thanks for all the help,
Tyler Berezowsky
Tyler Berezowsky
